originalaragorn
- Joined
- Nov 30, 2013
- Messages
- 3
- Points
- 1
Hi to everyone, take a seat grab a beer and listen to the weary travellers tale.
I have a w reg scudo 1.9, The engine started smoking, a garage said mmmm possibly piston broke (me on a sunday at 3am) compression test to be done. a friend recommended a mechanic (which he sorely regrets but no slight on him) The chap came and took it away and eventually said yes engine busted due to the end of an injector coming off and damaging the piston
, an engine was bought and winged its way over and he fitted it but neglected to swap the original parts over from the original engine (like fuel pump ect).
the injector pump is a lucas which has now been put on the new engine, fired up and was running as bad as old engine, ahhh you need new injector pump says mechanic, so £250 later new injector pump is fitted and now the engine won`t start at all, will turn over but that is it. It has taken him nearly three months to get to this point and today i lost my rag and towed it home. Now as far as i can tell there is fuel to the stop solenoid but no further, apparently there is a chip in it and can i bypass it, was also told that needs to be plugged in to a fiat main dealer puter to get ecu to recognise chip.
Any help, thoughts or walls to bang head against much appreciated :bang:
