Hello,
I want to add automatic transmission to the 1999 1.6L 16V 100 since it is the car I have.
I've done some research into this and I think the best bet for this to work is to replace the engine and transmission with one from a 1999 era Eurovan, like the Citroen Evasion and Peugeot 806 (couldn't find a 1999 Fiat Ulysse with an automatic transmission, if they were ever made).
If not, a 2004 Fiat Ulysse is also an option but since the Eurovan project was a joint effort between Peugeot, Fiat and Citroen, I'm assuming that almost if not all the parts should be interchangeable and if not, easy to adapt from one car to the other, especially from the start at 1999. If a 2004 Fiat Ulysse is good as a donor also, I have no issues going for that.
I'm also open to a Fiad Idea, as I don't mind the gearbox being robotized like in a Smart car, since the goal of this is to automate the gearshifts and clutching, not to do it with no pauses. The Idea would be ok for the parts but I would be going down in power and it's a last option.
If I'm going through the trouble of adapting it to an automatic, wanna give it some power also.
What are your thoughts on this? Is this project doable? What more do I need to get this done? Is it going to be relatively easy like I think or will it be a nightmare?
I've attached a photo of the gear selector from a 2004 Fiat Ulysse. Pretty sure it would fit into the Multipla with minimal modification. The problem would be the rest![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
