My A/c has lost gas. I haven't had it tested for a leak yet, so I'm hoping it's just a seal. If it's the condenser, could anyone tell me how to go about removing it please?
Thanks for the reply Andy.realistically you need to establish if the gas has all escaped or if its just too low on gas for the system to work.
It can be pretty dangerous to go taking things apart with still potentially very high pressure in the system even though there is not enough pressure for it to work.
Also it is illegal to knowingly release aircon gas into the atmosphere, therefore you should really be taking to someone to tell you what is wrong and have the gas sucked out of the system before anything is taken apart.
Once someone has looked at it, it may be it just needs a re-gas and there is no leak, all systems lose the gas over time.
Potential for damage then.. at least if you know it worked a month ago major mechanicals are obviously still soundAll was good then. Sprung a leak since
If it's a MK3, it'll be at least ten years old.Easy to spend £600/£800 if you need major work
At least a condenser (if needed) isn’t expensive @£100.Potential for damage then.. at least if you know it worked a month ago major mechanicals are obviously still sound
Is yours the cheaper gas ?
Last time I looked they were in the £30-40 bracket including shippingAt least a condenser (if needed) isn’t expensive @£100.
To be fair there are many many times you’ll do a vacuum and hold and it will all look fine as it’s only for a half hour or hour, so you regas it and off you go.Add some UV dye
The source of the leak will glow
I am surprised the AC shop didn't spot any problem if they held a vaccum before refilling the system
Under ultra violet light?The source of the leak will glow
Yes with special glasses and UV lightUnder ultra violet light?
BEFORE 2012 cars have a differnet type of gas and thats cheaper.....
I don't know if anything is different for the crossAny help on how to remove the front bumper on the Cross would be appreciated.
The vast majority of cars use R134a which was still in use up until 2017/18
The “new” gas R1234yf was supposed to come into use in 2010 except no one was manufacturing it so no one could get supplies to put it into cars. Some early adopters had it in 2012 but really most cars and manufacturers didn’t use it till 2017. )
Anyway the lates gas is considerably more expensive, usually twice the price of a refill and most places still don’t have the kit for it even now some 5 years since it became mandatory
Pictures of the new cross bumpers suggest that there are a few more fixings round the headlamps under the bonnet to be removed and I suspect the Mk3 will be very similar. Its basically a top row of fixings various and a bottom row, along the edges and a few round the wheel arches. Lower the bumper onto a blanket or quilt on the ground and remove the wires from fog lamps. Bumper will have to be pulled straight forwards once the bolts and screws removed to slide out of the slots on the car. Best to have two people so it doesnt sag on one side and then get stuck which risks breaking things.
