Technical 500c roof only goes as far as the spoiler.
Orpington, Kent UK
I've been playing with the soft top the last couple of days and taken advice from some threads on here. I've done the relearn procedure but the problem I have is that the roof won't go back beyond the second (spoiler) position.
I've also put a socket on the manual winder and once it gets to that position the nut won't even turn any more.
If the roof is back to that position and I touch the boot release, it puts if back to the front position, so it's as if the car thinks it's fully wound back.
Any ideas anyone?
Any ideas anyone?
Seems to suggest it's been removed and incorrectly re-assembled at some point.
Does the roof report any fault codes? I've a weird issue with my electric sunroof at the moment that my fiat specialist is trying to get their head around, fiat have requested a download, apparently they've a new wireless gizmo now that's cloud based that gets plugged in to the obd that they can analyse remotely. Are there position sensors on the roof?
Haven't plugged it into MES but as the car seems to have an ECU for everything I wouldn't be surprised.
The thing that concerns me is that it wouldn't manually wind back using the nut in the boot either.
Plugged into MES doesn't seem to be anything that controlled in but have found what seems like a broken runner both sides at the point it stops. I've tried to take some photos and have uploaded them. I imagine that is something to do with why it stops. Or it could be the fact that it stops that has broken them. IMG_1536.JPGIMG_1537.JPG
Here's a video which shows the split roof runners. Anyone know if these can be replaced individually?
This image is a bit vague but it suggests the runners are all interconnected by the fabric strap (6), and not available individually. There was no index of the item numbers with this image unfortunately.
I'm looking for something that tells me exactly how the whole thing works.
Thanks for that. It's the number 3 things that has broken. I may have to try to get a second hand hood. Heaven knows how that final bit works though. I don't know if it not working has caused it to break or it breaking has caused it not to work if that makes sense.
I've found a listing of the parts in that diagram. It's a US site but I daresay the parts are the same. https://www.fiatpartswebstore.com/s...embly=1099001&ukey_make=1200&ukey_model=19431
Also I found this video
The camera work is awful and I haven't watched it right through but it might give you some clues if you haven't already seen it.
Looks complicated but he describes the bits I have broken, so it's made a lot of sense. Still don't understand what stopping it from going all the way back though. Possibly the Motor or a blockage.
Just tried mine and found that if the boot is open, or just unlatched, the roof will stop at the spoiler and refuse to budge further. I don't want to muck around too much with it so I didn't try to turn the nut and see if you can still wind it down with the boot unlocked.
After viewing that video I understand a little more about the operation however and really wonder if the broken bits would affect normal running, especially stopping the roof exactly at the spoiler.
Mine's over three years old and the roof is used almost every time the car goes out so I'm wondering about lubrication of the runners. Has anyone done this and what was used?
If I recall correctly lubrication of the runners is part of the scheduled servicing in the handbook, don't remember the frequency, if it actually gets done is another thing.
Spike
Yes I agree there. I don't think those broken clips are the cause it's something more sinister. Interestingly, when the roof is wound fully open and you try to open the boot, the roof will automatically move to the spoiler position. When mine is at the spoiler position it moves back to position 1 so it's like the car thinks that it's fully open.
That could be because it's learned that it can't go back further than the spoiler and therefore that's the limit of travel. Do you still have to hold the button to fully close it from position 1?
