Technical 2022 ducato LCD instrument cluster ic retrofit to 2015 ducato
nikosgrk
greece
Is it possible, has anyone tried it yet?
Do they have the same wiring connector?
They are two types basic cmall lcd and full lcd
Has anyone tried yet?
Any part numbers of the instrument clusters and and also some photos of the rear side including the connector?
Please help!!!
I tried the full digital one but it does not work. any clues?
It may be rather old, but if you download the x250 Training Manual, via the Downloads button at the top of the page, and select or scroll to page 143, there is a pinout for the 18 way connector. There is more info on previous pages. Not a complete answer, but perhaps a starting point.
I should have added to post #6, that if the instrument panel, which is a node in the canbus is replaced, then a proxy alignment would be required.
Hi, I did not find in the downloads section the x250 Training Manual, can you help locating it please?
1. Click on "Downloads" at top of page. - Menu opens at left of screen.
2. Select "Fiat Commercilas", then "Ducato".
3. Locate "Fiat Ducato Training Manual" on page 2. click on that, then on "Download" at top right side of page.
4 Two file options, choose larger one (10.3 MB), as shorter file is for 3 litre engine.
Ok I checked out the instrument panel cluster pinout as stated in the attached photo for the ducato 200-2021 model.
I would appreciate if anyone can help finding some documentation for the ducato 2022+ instrument panel cluster pinout to compare.
Please help!!!
I found this info for the new series 8 2022 ducato
C015 DRIVER'S SIDE DASHBOARD MASS (DASHBOARD)
D001A FRONT/DASHBOARD JOINT (FRONT)
H008 ELECTRIC BRAKE CONTROL (DASHBOARD)
M001G BODY COMPUTER (DASHBOARD)
M114B CAN NETWORK SAFE CONTROL UNIT (DASHBOARD)
H090B SWITCH CONTROL GROUP (DASHBOARD)
M172A MULTIFUNCTION SCREEN NODE (DASHBOARD)
M094B RADIO RECEIVER NODE (DASHBOARD)
M001H BODY COMPUTER (DASHBOARD)
M060A AIR BAG CONTROL UNIT (DASHBOARD)
D227A CABIN/DASHBOARD JUNCTION (CABIN WIRING)
H091 DRIVER'S SIDE CONTROL GROUP (DASHBOARD)
