Can any members please help me -
I own a 2015 fiat Panda cross 1.3 mj (left hand drive) the clutch pedal keeps sticking to the floor, but can be lifted up again by using your foot.
The brake fluid level keeps going down despite several top ups, I have changed the complete brake fluid twice recently.
I believe that the brake master cylinder is a dual cylinder, and also operates the clutch?
I believe that clutch slave cylinder can only be replaced by removing the gearbox as this engine has a dual mass flywheel?
I'm presuming the brake fluid is leaking from the slave cylinder into the bell housing, there are no leaks on the brake circuit I have checked, and no leaks from the master cylinder to the bell housing on the clutch circuit.
As the car has completed 52,000 miles I intend to change the complete clutch assembly, that's a new combined slave cylinder/ clutch bearing, dual mass flywheel, cover and drive plate.
Has anyone changed their own clutch on a 4x4 here please?
I'm presuming both front half shafts would have to be removed together with the propshaft before the gearbox can be removed to access the Clutch?
Does the front side cross member where it connects to the front bumper on the gear box side, also needs to be removed to allow room to extract the gearbox?
I would appreciate any advice or information from any members who have completed a clutch replacement on their own 4x4.
I have checked shop 4 parts and the total cost of the parts would be approximately £585, I would be working on my own, from the floor, using axle stands and a trolley jack.
I have not contacted any independent garages at this stage, but I'm presuming the cost to replace the whole clutch would be in the region of £1,200?
If I completed the work myself I would
Save in the region of £600+
If any members can advise me on the potential garage cost I would be very grateful for Thier help.
Thank you.
Best regards,
Steve
Thank you.
Best regards,
Steve
