BargainHunterZA
- Joined
- Jun 6, 2019
- Messages
- 11
- Points
- 2
Hi all,
New to the forum & brand.
Picked up a minter 2003 Doblo 1,9 non turbo panelvan with 97 000 k's on odo with FSH at non-franschised dealer. Base model, no rev counter etc.
Has a few erratic issues. hot or cold:
1. Sometimes, it won't swing. Dead. Dash lights up, that's it. Leave it for an hour. She fires up.
2. Sometimes, she won't rev up, as if accelerator pedal is "dead". After a while, will rev up. Or, switch off and then she fires up again without an issue.
3. Has a very rough start, I suspect glowplugs, will check this weekend.
4. Has an over-rev upon gear change, there's a post elsewhere but youtube link is broken.
Other than that, she runs very smoothly, battery is new.
Previous Owner's Driver told me of these issues, suggested it relates to a removed alarm/immobiliser. Problem just seems to erratic to point to this.
Any other pointers to take into consideration?
Brake pedal not returning, leaves stop lamps on, easy fix. Horrible sway, shocks likely never been replaced.
Not shaken her down yet.
Been told that oil pump chain likes to fail at 150 000 k's. Will likely do this and cambelt ( no idea if one is fitted? ) and few other maint items over weekend.
Any leads?
Thanks!
Benjamin
Wintery JHB in South Africa....
Any leads?
Thanks!
Benjamin
