I have a 1998 2.5 tdi that just died on me. It had been sitting for a month where I had it on a long trip before that so no issues. It started just like normal, but when I was to set off I seemed to have stalled it and it just would not start up again. Turning over just fine, but no ignition and some white smoke out the exhaust indicating unburnt fuel through the system I think. I checked if any fuel came out of the recycling pipe leaving the injectors and it was very little I would say. Fuel filter was full, but replaced it as it was old anyways. Then I realized that there is no fuel coming from the tank and I thought these guys were supposed to have a low pressure pump to prime the system there. My unit has three wires where I think it is a common ground and one gets 7v for the fuel level and the other one is dead.
Does anyone know if I certainly should have a pump or if some of these do not and only run of the mechanical one?
I have not found a wiring diagram for mine and whatever work shop book I can find it seems not to cover it or not be for my van. Mine only has fuses and relays in/under the glove box where the owners book mentions a fuel fuse in the left side of the engine bay, but none are to be found. I also managed to trace the white/red wire from the pump/fuel sender into a mulitconnector on the left side of the dash where it still has conneciton to the tank, but no voltage - measured with the iginittion just turned on so no waiting too long.
Checked the inertia sensor behind the battery which seems fine. The immobilizer light comes on every third time or so, but a few attempt with the keys and it goes away as it always has.
Anyone with an idea of where to look next? If I have a pump and where it is fed from? Right now I get an open circuit between the white/red and the black in the three pin connector on the tank so seems to me there is no or a faulty pump, but I also get 0v so nothing is asking it to run either. I have also chimed the engine with everything connected except the fuel hose in to the filter and nothing comes out naturally.
