charliegrant
- Joined
- Nov 30, 2020
- Messages
- 2
- Points
- 2
Hi there. Just bought an Autotrail Pawnee motorhome in November 2020. It's based on a Fiat Ducato 1.9TD. I have a few wee things I need to sort through.
Easiest would appear to be replacing the near-side headlamp bulb.
Upon opening the bonnet I can see the headlight unit, and right behind that is the air filter housing. I removed the plug from the bulb & the rubber cover & I can get my hand down, but cannot work out how to release the clip that holds the bulb in. It's hard to do just by feel alone. I've searched the web but only the later models come up. i also bought a manual from Amazon, but no mention of bulb replacement. I though about removing the whole headlight unit though the manual say's not to. Taking 4 nuts off I get the unit free, but to get it out you have to take a long panel off. This is held in by a few screws (these appear to be torx) but the torx I have will not fit, I think it's rust in the torx head so I will persevere. Any advice/help would be fantastic.
Regards
Charlie.
Regards
Charlie.
