- Joined
- Feb 11, 2006
- Messages
- 6,866
- Points
- 1,040
arc said:theres an article in centochat about one, yeah
Guessing i need to become a member then? That can wait until the new year.
JR said:also IMHO the use of t/b's on the 600m was a complete gimmick to say they had done it, as those t/b's deliver there peak power (in the right application) well above 10000 rpm so useless for performance driving.
You would be better off with a modified punto mk 1 16v inlet manifold! Or a standard inlet manifold as they are suprisingly good on the 16v.
QUOTE]
The engine produces max power above 10,000 rpm.
The tbs allow it to breathe effectively at that level.
Not just the size of the tb but its straightness, smoothness lack of junk in the airway and quality of components that contribute to power. This will be effective throughtout the rev range and with a high overlap/lift cam that power will be produce further up the rev range.
Hayabusa = 147 iirc bhp @ 10500 1300 engine
So yeah, might be overkill on yer 1242 cento (mind you if your revving to 8000?) (cool tho)!
But, no, the Haybusas are gonna be way better than fiats finest inlet manifold.
Me, I just wish I was in a position to be playing with this sort of stuff
Liam said:Skinz have you done what I said?
Liam
davethetrike said:But, no, the Haybusas are gonna be way better than fiats finest inlet manifold.
SkinzCinqSporting said:Then there's just the matter of either getting an uncoded ECU or using standalone management
good luck to ya but what sort of performance are you hoping to get for that? Surely a turbo will be cheaperSkinzCinqSporting said:Well from what I can figure from what I've been reading...
panda-sport said:If you can get the code box and keys from the crash damaged punto then theres no need to uncode the ECU
J333EVO said:throttle bodies you say, money no object you say, then got to be Jenvey http://www.jenvey.co.uk/
Fivehundred said:Don't want to **** in your puddle or anything, but from what you've said recently your Cinq has lost some of its youthful looks. Personally I'd be wary of spending a shed load of money on converting a less than great bodyshell.
The other thing you need to factor in is the money you'll end up spending on the small boring stuff you'll need to make it all work, engine mounts, electrical connectors, bits of hose....... you'll be surprised at what it swallows up.
JR said:You will be fine, good luck!! Just get ready for lots of perseverance!
Just one thing you really shouldn't need to trim the inner wing, a spacer on the engine mount is much easier.
Get an uncoded 16v ecu and that will be fine, you'll be looking at some very good power.
Luke said:What about the 16v head on the 1108 block? :chin: Should work in theory? Just have to swap over the crank pully and source a shorter belt?
SkinzCinqSporting said:Tell you what luke, if it will work, then that's making life a bit easier. Still have to plug in the 16V loom though
