- Joined
- Apr 26, 2011
- Messages
- 2,102
- Points
- 358
Some useful information Bgunn. Change in direction for Fiat from IHI turbos and more recently the use of Garrett turbos on the MA and the APE and the GPA SS.
Don't forget the TA is small - Mitsubishi are pretty skilled in titchy turbos, so the others might not have suited the application required.
So with the 6 speed version of the C514 does that meant that it is not as strong as the 5 speed which is rated at 150Nm ?
Same rating - it's the same basic gearbox with a different selector (for the extra gear) and another gear tacked on the end under the pressed steel cover. The 85PS TA is quoted as producing 145Nm torque, at peak.
Given the increase in turbo size from the current model - do you reckon that the TD02 turbo is maxed out and that a Tuning box could shorten it's life ?
I don't think it's maxed out, but might not work optimally if the boost level is increased, as you'll move too far up the boost map, reducing efficiency and ending up with a very hot charge.
