Recently bought a very tidy <50k blue panda 100hp to replace my ignis sport which was written off by someone pulling out on me. It's my first Italian car so go easy on me (I also own a 1994 Porsche 911)
The previous owner seemd fastidious so I didn't have too many worries but in all honesty it's not been the most harmonious purchase as on the way home from buying it a rear bump stop detached, and I woke the next morning to find the gearbox requires a very soft touch from stone cold or else I can beat the syncros (hoping oil change will help this).
Whilst investigating a fix for the bump stop I notice some people suggest replacing them with ones from the lower model as it gives a more progressive bottom out, this would make sense as the 100hp plastic centered ones don't seem to allow a massive window for the rear damper to work in.
Also I would guess from everyone else's experiance the rear dampers will probably attempt fall off at some point, so any suggestions for replacements? The default choice seems to be koni str but as I understand they are for the base model so will have a longer rod length allowing the spring to become loose at full extension which I don't like the idea of. Bilstein, kyb and Sachs seem to make dampers specifically for the 100hp so has anyone got any experiance of these?
