the length should not be much of an issue, the extra length of a 1242 belt should be small enough for the tensioner to take out the slack fine..
as said you need matching crank and cam pulleys, common sense states to use the pulleys from the car the ecu you are using came from. So if using the p75 ecu swap the crank pully from the donor onto the 1108 bottom end - if using the cento ecu swap the cento cam pully onto the camshaft on the new head.
And then use which ever belt matches the pulleys.... so P75 pulleys and ecu use a P75 belt and if using cento ecu and pulleys get a cinq belt.
