dynoato
- Joined
- Apr 9, 2013
- Messages
- 3
- Points
- 1
:bang:hi I could do with some advice as my 06/07 Iveco/ ducato 120 multijet idles funny it ticks over ok but after 2 mins it makes a noise/engine note goes deep as if a flaps opening or shutting up and you can feel air blowing out of the air intake if you blip[ the throttle it stops the air blowing out of air intake and noise goes. when idleing for another minute it does it again .ie tried blanking the egr off it makes no difference ive replaced the egr vacumm control unit thinking it might be sending signals to ecu causeing fault ive cleaned the air flow meter with wurth air sensor cleaner ive done a leak off test on injectors .now thinking of replacing air flow meter and lamba sensor van runs ok but sometimes lacks power have taken it to garage they said they would have to replace all the sensors simply cant afford it I wouldn't mind buying a sensor if I new which one it was as all sensors working on elm327 obd but I don't know what the readings should be hopefull that somebody else has had this problem before please please any advice is more than welcome many thanks
