Hi there
Just purchased a 2006 fiat PUNTO 1.3 diesel. Baught with a starting fault.
It starts runs for two seconds then stop with management light flashing. I have recoded the injectors the car run fine for two weeks then stopped and lost codes.
Tested injector leak off which is fine. Fuel is getting to common rail like it should replaced fuel filter and crank sensor. But still will not start. Help or or comments needed for guidance. One last thing I'm thinking of sending ecu off for testing to see if this help also have a relay ticking noise coming from left hand boot compartment
Chris chapman
Chris chapman
