unbeetleble
Resently i took my tb off to clean and polish a bit when i came to replace it i found 1 of my injector plugs broken off of the injector body. Luckily for me i had a set of vw 1.4 injectors and they fit right in to intake mani and rail only prob is they are longer by 12mm ,so 2 4mm thick plates 25mm long by 20mm wide with 7mm holes drilled 12mm apart ,can be used to adapt ,so fuel rail can bolt to plate and bolt plate 2 intake mani
