Thread Tools
Old 12-09-2012   #1
Fuel pump change
Hi All.
Can anybody tell me if the high pressure fuel pump runs off the cambelt on the doblo.
might need to replace mine but don't want to mess with it if i have to go any where near messing with the cambelt.
Many Thanks.
Damo1 is offline Reply With Quote Quote
Old 15-09-2012   #2
s130 has donated!
Re: Fuel pump change
You don't say which Doblo. Petrol or Diesel and engine size.
If diesel then the pump can be replaced without disturbing the cam belt. Basically you use two bolts to secure the pump pulley in position and withdraw the pump from the back.
However I would be inclined correctly lock down the flywheel and cam shaft before proceeding just in case something goes wrong.
If you are not that far away from a cam belt change then it might be better to do the belts, water pump and fuel pump at the same time.
s130 is offline Reply With Quote Quote
Thread Tools
(T) diesel fuel pump change is it needed? orinoco99 Ducato 3 10-03-2011 11:27
(T) 2.0 20v cambelt change help and fuel filter change help Wilqaeda Marea 4 13-10-2009 12:20
(T) Shimming Fuel Pump or Disable W/ Electric Pump FizzyNose Uno 14 04-01-2009 16:15
(T) Fuel Pump Fitting/Too Much Fuel nerd8192 Punto (Mk2/2b) 1 09-05-2008 08:27
(T) JTD in-tank fuel pump, fuel return? Dax Stilo 2 02-11-2007 16:45
