FIAT Auto Specialist Team
Thread Tools
Old 19-09-2006   #1
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Engine fault/sensor fault JTD
As it says, three beeps, engine fault, sensor fault and no turbo?
Any idea's guys. Need it ready for Sunday or it's a no show
bozzy is offline Reply With Quote Quote
Old 19-09-2006   #2
SchooweeNick has donated!
Re: Engine fault/sensor fault JTD
Gotta get that fixed!!
I'm looking forward to my back, sack and crack wax!!!
SchooweeNick is offline Reply With Quote Quote
Old 19-09-2006   #3
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Update, not in limp mode, no turbo any gear and 75mpg!!
Any help appreciated.
Old 19-09-2006   #4
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Looks like I'm on my own here then.
Bozzy. Have you done a search on "overboost"?
Bozzy. Yes, seems many have had a similar problem so hopefully the dealers will be able to diagnose it tomorrow.
Bozzy. Good luck with it, let us know how you get on.
Bozzy. Wil do.
Old 21-09-2006   #5
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Quote Originally Posted by bozzy
I get the three beeps followed by engine fault (red engine block on display) but nothing else.
Are you actually getting "Sensor Fault" & "No Turbo" displayed
Pretty sure my mpg is down rather than up.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 21-09-2006   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
First 'port of call' to check is overboost valve.
Old 21-09-2006   #7
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Quote Originally Posted by T14086
I mentioned this to the tech at Hylton Fiat after reading the threads on here and he said "not at all", MAP sensor needed. If it doesn't work he will swing.
Old 21-09-2006   #8
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Quote Originally Posted by Argonought
Argo, got a warning light, engine failure, sensor failure. No mention of turbo on the panel but you know that it ain't there.
Sensor failure dissapeared, warning light dissapeared, turbo re-appeared all a day later.
Old 21-09-2006   #9
Argonought's Avatar
It's a been a pretty weird day for me as my 'gut' reaction was that I've not used the turbo enough (last two months have barely got out of town) and today on a 250 mile return trip decided to make up for it once the turbo came on line (when the engine light goes out). Found if I kept it on turbo then it tended to stay in but would tend to drop out (and stay out) at lower speeds. I think you can follow the drift of how this affects driving style
What's weird is that you can be flying like a 'bat out of hell' one moment but struggling to overtake anything (and I mean anything ) the next.
If I don't get this fixed soon I'm likely to be parted from my licence
Old 21-09-2006   #10
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Mine was either there or not, no blipping between turbo/ non turbo. Weird and frustrating.
Old 22-09-2006   #11
Forum Moderator
T14086's Avatar
T14086 has donated!
Map/throttle body update been done?
Old 22-09-2006   #12
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
T, the update was done but they wiped my angeltuning re-map so when I had another re-map it was probably removed.
Since Wednesday night it's been tip top, no warning lights and full power.
I took it in today and when I collected it the chap said it's all sorted now and they have removed the error and turbo working normally. I said that's how I dropped it off this-morning. Have to say these guys are really terrible with their customer facing skills. A VERY old man was trying to tell the man his Punto (Grande) was banging when he steered around a corner. The manager said "I aint arguing with you pal, there's nothing wrong with it". Another customer jumped to the old fellas defence and asked him if that's anyway to address a senior citizen? Fair play missus.
That's the second incident I have seen here this week where had it been me I would have asked them to come out onto the forecourt. Last week I was at JCS, another main dealer and the beaviour was outstanding so I know it's limited to a few bad eggs.
Old 23-09-2006   #13
Argonought's Avatar
Lightbulb Re: Engine fault/sensor fault JTD
Mine's now sorted
Removed the overboost valve (mine had already been moved up by the side of the battery tray). Noticed the problem straight away. Although someone had done a nice job of moving the valve they'd reconnected the pipework with cheap rubber tubing which had started to perish and quite a sizable hole had formed where the rubber had split.
So it turns out the engine fault light had nothing to do with lack of use of turbo, as I'd first thought, and was just down to a dodgy piece of rubber tubing
I've made a cleaner connection now using a jubilee clip to hold it on firmly.
For anyone that owns a JTD I'd strongly recommend:
  1. Make sure your overboost valve is located up by the battery. This would seem to be a standard Fiat mod so best get it done by your dealer if it's not already there.
  2. If it's already been done then check the tubing carefully for defects.
  3. If you get 'Engine Fault' and turbo drops out on a journey then have the sense to stop and check the tubing is tight on the overboost valve instead of driving for nearly a 100 miles like I did with an intermittent turbo!
Old 23-09-2006   #14
Veracocha
bozzy's Avatar
Trader Rating: 3
bozzy has donated!
Argo, great info but I swear I cannot locate that part anywhere under the bonnett ???
Old 23-09-2006   #15
Argonought's Avatar
Maybe yours is still low down by the nearside front (under the headlights I believe according to T14086) although that wouldn't make a lot of sense as I think you have a newer model than mine
Thread Tools
(G) How many Stilos activematt Stilo 755 12-11-2007 15:17
oil - question for GC Hellcat Lets Talk FIAT 47 17-01-2006 13:54
Rolling roads figures, fact or fiction? J333EVO Lets Talk FIAT 18 01-11-2005 16:36
(T) engine swaps HP Cinquecento / Seicento 0 31-12-2004 01:17
