If its working for you Jay then but please dont abuse the wood you could go blind
alexGS said:I'm really impressed by the quality of the posts here - lots of useful information!
stilojay, even though the wires you highlighted may not be the ones you thought, I think the important point is that you drew this troublesome connector trio to the attention of people like myself. I personally agree with NumanR and T14086 (what a name!), since airbag connectors have to be a unique colour (yellow or orange). Deckchair5 provided even more insight (posts like that take ages to write, y'know ) and so it is that I think we can all agree on the most likely causes of the annoying airbag warnings!
I have had similar elusive problems with crimped connectors in the past (low-voltage, low-current systems) and I know how I like to fix them; remove each pin one-by-one and solder the wire to the pin... not sure if this is possible with the airbag-type connector.
I usually hang out in the Uno forum - but now that I own a Stilo, I plan to spend a lot more time here
Thanks,
-Alex
Deckchair5 said:Haven't had any air bag warnings now since the cleaning so I believe I must have "hit the spot"
