Was poking around in the skyport control switch bay today (the one that sits behind the front interior light & map reading lights) and discovered the wiring for the factory fitted alarm even though my Stilo was never fitted with one! :woot:
It's the 4 pin connector on the left. If your Stilo has one then you'll need to fish it out as mine was taped up a good way back into the recess (have a good look with a torch). It carries a lot of information so I can only assume it's a combined power and CAN feed. The module it plugs into carries both TX & RX ultrasonic heads, plus the switches to dis-able the anti-jacking sensor (which may be in the module too) and also the volumetric disable switch.
These switches light up at night with an amber glow and also include green LEDS to show when active etc.
That said - I still haven't got a working alarm so it looks like another module might be needed - or perhaps something needs setting with 'Examiner'.
If you've got this cable then you can buy the complete housing which includes all the above plus the skyport switches for £160 from a Fiat main dealer. Think I'll have a talk with my local dealer tomorrow and try to find out what else I need as it seems pretty clear that the car is pre-wired for an alarm.
Anyone like to suggest what the spare 2 wired plug on the right is for as its got me beat? :chin:
