kernowstilo
- Jul 25, 2013
- 8
- 3
Hi everyone,
I've been having some issues with the stilo, jtd 8v engine 2004.
It was running cold, then suddenly started overheating on anything above tickover revs.
I changed the thermostat last week with help from Davren, but the issue remained. So having read posts, decided it was the water pump.
I got the timing belt off and the water pump out, and yes it was the water pump, the impellor was just spinning on the shaft and not providing any water circulation.
It was all going well, got the new pump in, new belt on, timing marks lined up. Tensioned up the belt by pushing it across, then tried to rotate the belt using a socket on the pulley.
My issue is that there wasn't enough tension in the belt, the top two pulleys moved in synch, but on the bottom pulley the belt slipped over the teeth, I did this at least 2 or 3 times before I noticed!
The timing must now be WAYYY out. Any ideas what I do to sort this please??? How do I get the timing back in synch? I'm guessing this is not good.
cheers nod
cheers nod
