Piotr55122
- Mar 8, 2015
- 1
- 1
Hello everyone
I have problem with my Stilo (1.6 103HP). Engine very bad work. Car accelerate unevenly/ In regular interrupts. When I keep it on at higher speed engine (expamle 2000rpm) engine waving in terms of 2000-2300rpm. Enigne bad work on idle speed almost like a 3 cylinder. Errors that occur are P0420 (catalyst converter).
I replaced: catalyst converter, spark plugs, timing on the blockades.
I clean a trotthle and learn throttle.
I check:
- ignition coils - OK
- timing again - OK
- compression - 12 Bar on each
- sonda lambda - OK
- intake manifold leak - tight.
On high speed engine smokes on black. Average fuel 7,5 liter/100km. Course 106000 miles. Manifold pressure 370-420 mBar.
(see 15s)
I haven't idea Please help...
Sorry for my english.
I check:
- timing again - OK
- sonda lambda - OK
(see 15s)
