Technical Rear Wheel Bearing
misu
Member
Please how to make the rear wheel bearing replacement, thank you ..
1) hand brake on, put vehicle in gear
2) take center cap off wheel
3) remove brass 'nut cover'
4) straighten lock tab on nut (if it has one, some cars do, some cars don't)
5) loosen hub nut and wheel nuts (dont take all the way off, just loosen them)
6) Jack vehicle up and put on axle stands.
7) remove wheel
8) release handbrake
9) remove brake caliper, pads and carrier
10) remove brake disc
11) remove hub nut
12) remove hub assembly
refit in reverse order with new parts... do you want torque setting for refitting?
7) remove wheel
11) remove hub nut
Do you have the Torque settings? Need to do my rear bearing. Cheers.
Autodata says 250Nm... i wasnt too far off ;) happy fixing
Cheers mate I put it on last night but I'll check it tonight. I dont know if you know much about these but even though I've replaced the suspected bearing there is still a droning noise when I'm driving. it's driving me nuts! Any ideas what else it could be? I really can't pin point where it's coming from either ?
I have to replace my bearing and would like to know the size of the nut that holds the bearing. (Then i know if i have to buy new tools :))
