Dear all,
hi, since a couple of days ago i've got a sticking rear brake problem on my fiat Stilo from 2005. first i noticed the sticking rear brake pads moving the car after standing still for 2 weeks with hands brake on.
i thought it would be a temporary issue, but i see that the problem remain. you can feel the brake disk is much warmer than all other three wheels brake disks.
after alot of google search and couple of youtube videos, i tried first to disassemble the calliper and clean/lubricate the sliding pins which didn't help. then i bought a whole calliper assembly from salvage yard, and replaced the the whole thing, winded the piston back (which was hard to wind with the proper tool), bleed the brake, but still no improvement. i thought the brake hose may be an issue, but i see with bleeding that plenty of fluid comes through...
somehow, from the first time brake after install, the piston fail to retract and the whole thing get stuck!
i really dont know what reason can be. of course there is a chance the second calliper may also be dead but the seller says that they test the parts and they works and they give three months guaranty... i can buy a new calliper but i wonder if that would solve the problem, and of course i try to avoid unnecessary costs. i checked the ECU for error, there are no faulty errors on engine ecu or ABS system either.
i wonder if there are people with similar problem who wants to share their experience. what blocks the oil in the brake to go back and the piston fail to retract after releasing the brake (hand and foot-brake). could it be a failure in abs system (drain valve) and is there any way to check that out since there are no error records?
anyway, any help will be appreciated.
best regards
best regards
