If I was to pop into Halfords and buy a top up tin and gauge what pressure should the air con be on my 1.2?
i thought you had to go in to a garage to get your air con topped up as you have to be "trained" to use the equpment ?
Make sure you are in the "green area" of the gauge, and it would be ok. I've topped up mine twice, you dont' need rocket engineering education to do it.
You don't have to, but its silly not to as its normally the same price or cheaper than the halfords DIY job, and they'll remove all the old stuff and replace it rather than just top it up, and will also pick up any system leaks etc.
if i recall the total amount of gas that has to be in is 550 grams
All done and what an easy job but.........
Sometimes the air con wont come on. Is there a pre set temperature where it starts to work? I ask this as its been chilly yesterday evening and today when I was out and about and the air con only came on once.
