Hi guys
just a quick word of warning, my brake pads just started to grind tonight on the way to work, i was a bit surprised as the warning light hadn't came on and the brakes looked ok when i looked over the car yesterday.
The n/s had worn right down and broken up, the warning cable had popped out and was hanging down!!!
drivers side was also heavy worn but both pads on the outside had loads of wear left (thus leaving me with a false sense of confidence in their stopping ability).
I had the drive from hell home, 25miles and i didn't touch the brakes once other than when stopped - using the gears and handbrake was very effective lol.
Luckily i keep a stock of brakes, disks, bulbs, oils, and filters, and changed the brakes in under 20mins both sides!!! AN NEW RECORD FOR ME lol.
They were cheap pads (pagid), ive now got a descent set on once again (bosch), and luckily the disks were still serviceable - with my careful drive the disks are still un scored.
Ive never been so thankful to my draper brake compressor set, it made mincemeat of the cylinders, usually im swearing into it after 30 mins trying to return the cylinders with the handle of a hammer.
So guys check the inner pads and makes sure the wire is intact on the nearside.
