ok soooo ive FINALLY managed to track down a CN+ unit from a fellow FF member, also i might have bought myself a MF Steering wheel off of a 2.4... unfortunately im going to have some connection issues... namely antennae for the GPS, GSM (phone), and microphone unit.
GPS i could probably deal with if i knew what kind of cable was used... hint, HINT!!
the phone isnt that important to me personally BUT i would like to install it for that OEM functionality should i ever come to sell her
now as i understand it fiats GPS/GSM antenna was built into the aerial base at the back of the roof aaannnddd it probably used a different aerial, for the different wavelengths.
ive seen the punto window mount GPS unit HERE so id need to source the correct cable and a generic GSM unit HERE which i can only assume would work. as for the microphone... does it use a standard jack connector? im guessing not because its fiat
which one of you all knowing fiat bods would be able to help?
