Hub changed. Tadaaaa! Removal of the big nut didn't go as smooth as planned, so: Hail to the hydraulic impact driver! :slayer:
Will post pictures and videos of the progress...
I told you that nut would be tight! Did it even defeat a 2 metre scaffold pole?
(except i wish i paid for taper roller instead of ball type bearings)
just to add i did my rear hubs with 50mm extension bar on socket with 1M bit of scaff bar no problem (except i wish i paid for taper roller instead of ball type bearings)
one side of mine was taper so someone does them
a castle nut
