I am needing to to change the rear wiper arm on my fiat stilo 04 reg. can anyone direct me to where I can change it myself as the garage will want money for a quick job. Not ....
Easy job to change yourself. Part of the piper arm flips up where it connects to the the wiper motor, in the middle of the rear windscreen. Flip the plastic up and you will see the nut that holds it on, remove the nut and the arm will come off. Easy
Er, did mine a couple of months ago, the arm had cracked so I pulled it off leaving the aluminium sleeve on the spindle. I cut into it very gently, then split it open. I then cleaned up the shaft and put the new one on. Works fine now.
