Gordon1610
hi...if you are thinking of removing bumper to change your headlight unit , here are some things you need to be aware of as it was a nightmare on a 2002 stilo...most of the torx screws were rusty and would not budge so resorted to molegrips and brute force with wd40 ....the nuts holding the headlight unit in place were very tight and i snapped x2 of the guide pins while undoing but , luckily still had enough to hold new unit on !! the torx screw attached to wing is very awkward and tight but if you place a screwdriver in the holes of the torx screwdriver it gives you extra leverage and loosens eventually. some might say to let garage sort it but k/flit wanted £250.00 ????? e bay came to rescue with new unit for £45.00. after giving up 10 times and then thinking about cost saving , i sorted my new unit and everthing now works ok ...just thought you ought to know...only attempted after reading guides and posts on this lifesaver of a forum ..thank u all guys and girls ..keep up the good work..........
