F fender mender Patron member Joined Jul 9, 2011 Messages 254 Points 86 Location telford Feb 13, 2012 #1 can any body tell me which ajuster on the head lights lifts them mine are a bit low
N nikkiy9 Rallying Crazy guy Joined Jan 11, 2009 Messages 806 Points 244 Location Newcastle Feb 13, 2012 #2 0 is the highest height, 3 is the lowest
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk Feb 13, 2012 #3 fender mender said: can any body tell me which ajuster on the head lights lifts them mine are a bit low Click to expand... I honestly can't remember but half a turn should be enough to see if the height is adjusting. If not you've the wrong kno, turn it back half a turn and then try the other
OP OP F fender mender Patron member Joined Jul 9, 2011 Messages 254 Points 86 Location telford Feb 14, 2012 #4 i will try that when it gets dark thanks
vladof Light Seeker Written a guide Joined Jul 23, 2008 Messages 873 Points 143 Location Bucharest Feb 14, 2012 #5 The one nearest to the the wing adjusts the vertical movement of the beam (up and down). The large one is for left-right tilting. You need to adjust item 2 in the picture. Take a looksie here as well https://www.fiatforum.com/stilo/212322-stilo-headlamps-beam-allignment-pattern-adjustment-3.html Last edited: Feb 14, 2012
