Morning all,
I've done a search and can find parts of my issue but not the whole problem I have.if ive missed it
I have an issue my boot wont unlock when unlocking my car I have checked all the settings in menu and tried with and with out but no joy, the boot open button on my key doesn't to anything but while I am in the car I do hear what sounds like a relay opperating from the front end. I could live with this if I could use my key to open the boot but no just there I can barely get my key a third of the way into the lock I have tried WD40 on and the lock and no improvement there
is there any way I can open my boot from the inside I will be purchasing a new solenoid from the posts I have checked this seems to be the issue and not to bad to change once I can get this open.
I did drop the rear seats and crawl though but couldnt seem to get the trim off after removing the 2 retaining bolts inside the handles (is there a knack to removing this?) so I couldnt inspect the lock from the inside.
Thanks in advance,
Thanks in advance,
