Thread Tools
Old 14-01-2012   #1
Stilo Passionate
andreist31's Avatar
andreist31 has donated!
Memory Champion, ZNEMDROPS Champion
Unhappy Stuck brake pad on disc, rear left wheel
Hello all, any idea why my left rear pad got stuck on the disc ?
It cause it to heat up, evaporate a bit of brake fluid and now I have air in the system
RAC are on their way, just need to unstuck pad and bleed system and should be fine right? Braking pedal is quite flappy, if i press it a few times its stiff again -> air in the system...
Cheers,
Andy
Ps need help asap as i've broken down 4 miles away from dolgellau, was on my way to liverpool now...
andreist31 is offline Reply With Quote Quote
Old 14-01-2012   #2
Moderator
gadge's Avatar
gadge is part of the official FF Events Team :)
gadge has donated!
Re: Stuck brake pad on disc, rear left wheel
i'ld say the only way a pad could get stuck like that is that the sliders that the pad moves on are all fowled up? or that the handbrake mechanisim has stuck on, on one side? if u can, place a chock on the wheel or have someone step on the brake whilst the handbrake is off and have a look under the car at the back, the lever that the cable is on should be down on both sides.
TURBO SYMPHONY
gadge is offline Reply With Quote Quote
Old 14-01-2012   #3
Stilo Passionate
andreist31's Avatar
Quote Originally Posted by gadgemyster View Post
I got it towed back home.. it's the piston in the brake caliber. It corroded and got stuck. The recovery guy tried everything to unstuck it (i.e.: wd40, push it back in etc... in the end he tried to take it out and when trying to unscrew the pipeline bolt it was so stuck it broke, so now the caliber it definitely gone. Anybody got ideas how much will one cost?
Andy
Old 14-01-2012   #4
free if you claim it back off the recovery guy... standard mechanicing rule = you break it, you buy it!
Rich
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks.
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust.
richydraper is offline Reply With Quote Quote
Old 15-01-2012   #5
Stilo Passionate
andreist31's Avatar
Quote Originally Posted by richydraper View Post
True, but it was broken anyway, poor guy tried in freezing cold for almost two hours to unstuck the piston and wind it back without managing it. It's just not in me to do this, I realise it was gone already, he just tried to put me back on the road for another couple of days. Maybe I'm letting him off to easily but that's just me
Andy
Thanks kiopo thanked for this post
Likes Davren, kiopo, alsimmo liked this post
Old 16-01-2012   #6
fiats = frustration
roy lovelock has donated!
approx 75 from euro car parts, they exchange and re manufactor the old one so you need to whip all the bits off..
edit OUCH 103 now!!!
http://www.eurocarparts.com/ecp/c/Fi...3636154&000048
i only replaced one about 7 months back that is a big jump in price!!
You may want to go about rebuilding yours if you have the know how and tools to do it, you can get seal kits pretty at reasonable prices, but you still need to remove the crude and replce the internal piston.
Current:
2006 Peugeot 407 sw 2.0d
2004 Fiat stilo 1.9 jtd dynamic multiwagon
2004 Fiat Stilo 1.6 Dymanic Multiwagon - sold april 2013
2003 Fiat Stilo 1.6 active aircon (with EBD) - Written off 22nd dec 2009
roy lovelock is offline Reply With Quote Quote
Old 16-01-2012   #7
Stilo Nutter has donated!
I went with these guys ;-
http://www.ebay.co.uk/itm/Fiat-Stilo...49436215652166
And they are great. 30 refunded per caliper when you send back your old one. I got both sides, so it cost 120 for both (after the refunds) which isn't bad. They come with a 2 year/24,000 miles warranty which is pretty good.
Just check or contact them confirming which of their adverts are for your particular stilo engine & body variation & the correct side needed.
Stilo Nutter is offline Reply With Quote Quote
Old 16-01-2012   #8
Stilo Passionate
andreist31's Avatar
I actually went with these guys:
http://www.ebay.co.uk/itm/1707380781...84.m1439.l2649
I'll get it tomorrow morning, will let you know if everything is ok. Knowing that I've been quoted 170-200 almost everywhere it was worth getting this one and trying it
A
Old 19-01-2012   #9
Stilo Passionate
andreist31's Avatar
Finally fixed it lads, total cost was 50 caliper plus 40 local garage for installing it. I don't think that's too bad like. Handbrake doesn't feel as effective though( need to pull it up properly to hold, once it holds it's good, but I had a short run on it before), any ideas on that?
Andy
Old 19-01-2012   #10
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
The garage may not have followed the correct procedure for adjusting the handbrake after replacing a calliper.
  1. With the handbrake off, loosen the cable adjuster nut 5 or 6 complete turns.
  2. With the engine running, pump the brake pedal vigorously about 25 times.
  3. Adjust the cable adjuster nut so the handbrake holds the car securely on 5 clicks of the handbrake lever ratchet.
  4. With both rear wheels off the ground and the handbrake off, check that the rear wheels spin freely.
  5. Test drive the car enough to get the rear brakes hot, then repeat step 4.
Handbrake cable adjuster is behind the center armrest.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 19-01-2012   #11
Stilo Passionate
andreist31's Avatar
Quote Originally Posted by Davren View Post
Tidy, cheers Dave, will do that this weekend
Thread Tools
(G) Brake pad and disc source Andymacselespeed Stilo 6 11-12-2009 16:23
(T) Multipla rear left wheel stuck vesblade Multipla 2 03-12-2009 14:19
(T) Brake disc and pad wear 1.2 Active Ffoxy Stilo 18 11-06-2009 14:59
(G) Disc and Brake Pad Wear?? Ophio Panda 11 14-10-2007 10:35
(G) Brake disc & pad advice for coupe 20v turbo rexcoupe lover Coupe 4 21-09-2006 19:10
