I've had the P0235 error pop up a few time recently so I've replaced the MAP sensor, Boost Valve and the small boost valve pipes in an effort to pin point my problem.
So positive and negative pressure pipes relating to the turbo have been checked and suspect parts replaced but still when the car hasn't been used for a while I get the same error(P0235).
If I drive the car for 10 - 15 minutes then clear the error no matter what I do I cannot reproduce the error. However, if I wait a few hours, jump in the car drive to a local dual carriageway and floor it, up pops the P0235 error. The car drives great, no noticable loss of power apart from when the error pops up, she pulls like a tank even with the error displayed???
Attached is 3 graphs.
The vertical line on the top one is second gear.
The vertical line on the middle one is third gear.
The vertical line on the bottom one is fourth gear.
Can anyone see a problem or suggest other parametersI should test?
