This is the drawing i have seen but you know electrical drawings they are baffling, is it simply, one resistor end to positive(red) the other to the pulse feed (brown) the diode from brown to the negative lead(blue)
yes that is what the drawign is describing....a VERY simple circuit to replace something that is quite complex....another one ive seen on the forum is:
but im not quite sure how you'd make it, as there seems to be a bit missing...
This emulator emulates signal of occupied passenger seat recognition sensor for FIAT Stilo. Emulator shows that passenger seat is always occupied and airbags will deploy in the case of collision. Easy to install: You must connect only 3 wires, seat disassembling and faults erasing not needed. http://cgi.ebay.co.uk/Airbag-Occupancy-Sensor-Emulator-Fiat-Stilo-/180664069766
The other thing, there is a OCS emulator on ebay, it has red, white and brown leads and hes said that the same is under the seat? is that correct? if so which one is pulse and which is Pos and Neg?
i highly doubt that a single diode and resistor will replicate what the airbag ecu needs to see....id forget that design for a start. either consider making one of the more complex ones or buy the emulator from ebay
All that german at the top basically says is he takes no responsibility if you balls it up and break yr vehicle.
Bottom bit for cable labels is pretty obvious
I found these. Not had money to buy one yet tho...
