Thread Tools
Old 01-02-2011   #1
jim cooper has donated!
Track rod end lock nut
Does anyone know the size/type of nut that locks the track rod end to the steering arm (the rod that comes out of the steering rack) on a Stilo 1.4 16V. One of mine is rounded off but they are not supplied with replacement track rod ends.
jim cooper is offline Reply With Quote Quote
Old 01-02-2011   #2
Yellow Peril has donated!
Re: Track rod end lock nut
Quote Originally Posted by jim cooper View Post
Why not remove the nut off the other track rod and take it to a bolt and tool suppplier for a match?
Thanks jim cooper thanked for this post
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is online now Reply With Quote Quote
Old 02-02-2011   #3
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Do what I did and find a bolt that goes into the new track rod end and then find a nut that fits that bolt. I have one seized on the car on the adjusting rod so I'll be grinding that one off and fitting new
It's a very coarse thead of 8 tpi and nut inside dia of 0.4" (10.2mm)
Nut size across the flats 21mm
I think that'll be a metric size 12 coarse thread
My local ironmongers. steel merchants didn't stock it and they normally have everything. Metric coarse is pretty useless and just used on wine bottle openers and for gold diggers winding wedding rings on Hugh Hefner when he's asleep etc
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 02-02-2011   #4
belle macchine!
Ics19 has donated!
eper shows the nut coming as part of the track rod part, so no separate nut by the looks of it from FIAT. It says it's the same part as our JTD - I had quick measure with calipers on ours and it's 14mm across the rod thread, so M14.
It's easier to measure the external rod thread than the inside of the end. Unfortunately, it's impossible to get a good reading on the thread pitch without the wheel off.
Best to measure across 3 thread ridges and then divide by 2 (to minimise any errors) to get the pitch - looks like 1.5mm or 1.25mm to me, which is metric fine pitch type, but you need to check. They should be high tensile grade 8.8 or higher.
Ics19 is offline Reply With Quote Quote
Thread Tools
(T) Track rod end marts600 Marea 6 15-02-2007 11:05
(T) track rod end socheeky Cinquecento / Seicento 7 10-09-2006 18:29
(T) Track Rod Nut paul_treg Cinquecento / Seicento 8 15-06-2005 22:10
(T) Track Rod End jamie86 Cinquecento / Seicento 4 14-12-2004 11:18
(T) Track rod end arseofbox Cinquecento / Seicento 18 22-07-2004 22:20
