I thought i would point this out, i just suffered the poxy broken turbo pipe on the mw. the inner wheel cover on the n/s rubbed though the pipe over the years. constant whoosh when it kicks in (does sound nice but performance is lowered as well as consumption).
I tryed fiat, they wanted to sell me the complete pipe system, from intercooler to turbo, only the rubber pipe on the end is needed (approx 1 ft max) - not bad at over £80 with a 3 day lead time.
I cut my orginal pipe down and made good then looked for a generic pipe,
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=SAMTCH6.5B
it come in 1 meter lengths, mine came to £19 including express delivery.
you need to twist it about abit to make it fit but as there is so much its ok, also make sure you cut out that bit of plastic whilst your there to stop it reoccuring further down the line.
you will also need a couple of jubbly clips (75p each at a1)
oh yeah its bore size 54mm.
hope that helps someone out.
roy
roy
