Hello chaps,
I was considering blanking off the EGR valve on my stilo & multipla to stop the manifolds gunging up with the black stuff and stopping the black smoke on acceleration. Having read about it there seems to be some good reasons to do this. eg Here's a quote from someone on ebay:
EGR (Exhaust Gas Recirculating) valve basically recirculates spent gases back into the engine to be re-burnt, this only creates problems at the m.o.t station and when driving your vehicle on the road. Once it has been removed, the black smoke will go, you will get more mpg and b.h.p and the engine will run cooler, lets face it , that's why an inter-cooler is fitted, to cool the air entering the engine so why heat it up again with spent exhaust gases??. Using a thin blanking plate alone is a cheap bodge, and one end of the egr is still connected to the exhaust, which enables gases to reach the egr and clogging up the pipework, which cause it's own problems so that is why I removed mine totally and blanked it off on each manifold, allowing the engine to run cleaner like the Shoguns do, which I did used to own. I have never once regretted fitting this kit on my 2.8 tdi Pajero over 4 years ago, the engine is more responsive, there is no huge cloud of black smoke behind me, there is no turbo flat spot, it passes the mot emissions test each year with no problems, and it's all round alot better to drive, and especially to tow with.
So I was wondering if there is a blanking plate available for the JTD, or would simply disconnecting the electrical connector do the same job (to ensure the valve is always closed). Anyone tried this ?
Thoughts appreciated.
RRP
RRP
