The FIAT Forum
Go Back   The FIAT Forum > Guides > Stilo Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->How to fit a front upper strut brace!<!-- google_ad_section_end -->
Strut brace fitment for stilo all models!
Published by Ben R
27-11-2005
Tools you will need
Tools you will need.
1. 3mm drill
2. 4.5mm drill
3. 5.5mm drill
4. Small tube of copper grease
5. 1 large cable tie (selespeed models only)
6. Small open 10mm spanner
7. 10mm socket, ratchet & extension bar
8. Marker pen
9. 17mm spanner
10. 24mm spanner
11. Hobby/hack saw (selespeed models only)
Please note: When drilling the suspension turrets, if you've got some wear protective goggles, don't push too hard on the drill as the suspension turrets are very thick metal & you may damage your drill or possibly snap your drill bits.
Contents
Article Tools
<< <    Next Page: First off, marking out. (Page 1 of 6)    >  >>
Old 27-11-2005
Trader Rating: (0)
James Abarth has donated! United Kingdom
Re: How to fit a front upper strut brace!
I gave the Strut Brace a good testing on the way home. 100% improvement from such a simple and cheap mod. Cornering roll is reduced, no more understeer, more sensitive and precise steering with plenty of feedback. Well recommended, well fitted and well done Ben - thanks mate
James Abarth is offline
Old 27-11-2005
doM repuS
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
BTW, I intend to make the photos bigger
Nice How-To though
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 03-03-2006
Trader Rating: (0)
hey mate im kinda stuch i ahve the same stutbrace as you.it wont go down because its hittins somtheing.like a tube.it kinda looks like a nos can.do i need to unbolt it?thanks
Ryan m is offline
Old 02-05-2006
Orka inte
Seraph's Avatar
Trader Rating: (1)
Seraph has donated! United Kingdom
Consider myself braced. Great guide. Worked like a charm. Never again will I need a garage to fit a strut brace.. can't believe how easy it was.
HO! HO! HO!
Den som väntar på nåt gött väntar aldrig för länge
I think you'll notice when I turn this way, I'm done talking to you!
Seraph is offline
Old 07-08-2006
Trader Rating: (0)
spike192 has donated! United Kingdom
All,
Just a quick heads up on the front strut brace.... only relevant if your a selespeed owner!
It would appear the Fiat in their wonderful wisdom have at somepoint changed the selespeed reservoir. When I came to fit the brace on my 54 Stilo, there was no way it was possible with the reservoir. When comparing the pictures, the reservoirs are totally different.
08 Bravo 1.4 T-Jet
(All the options except for the MP3 CD Player.... who needs it anyway!)
Drive it like you stole it!
spike192 is offline
Old 08-09-2006
mscortar's Avatar
Trader Rating: (0)
Romania
I think JTD's might have a problem with this procedure as; the fuel (or is it the oil) filter is in the way of the strutbrace; I remember there was a post in which someone said that she lowered the filter a bit to allow the strutbrace in the engine compartment...
Stilo 1.9 JTD, 145 BHP (re-mapped), Sassi Grey
mscortar is offline
Old 11-03-2007
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Hello. This is an excellent guide, which I followed until I reached the last point...
After mounting my OMP brace I found it strange that I should pull the brace ends inwards (shorten it). Stress over years of enthusiastic driving will most likely make the suspension turrets bend inwards, and hence the need to be pushed further away from each other, to it's original state. Result: The car is now even more stable when cornering. But... am I totally wrong here?
Regards, Morten.
jet blue. 17" blades. eibach pro system. omp strut brace. gsr breath. mattig face. debadged. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline
Old 20-03-2007
Trader Rating: (0)
Nice tip Morten. I've just adjusted mine as you suggested and got more than a full turn of the adjuster in the opposite direction (lengthening the brace). Now we just need someone with lots of engineering know-how to come on here and tell us it's the worst thing we could have done! But until then, we'll enjoy..!
Phil Thomas
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive
Yellow Peril is offline
Old 27-06-2007
PNL
The modfather
PNL's Avatar
Trader Rating: (0)
PNL has donated! United Kingdom
Cool Re: How to fit a front upper strut brace!
I believe that the brace should be in a neutral position neither pushing outwards or pulling inwards at the turrets ..I am in the process of building and designing a new turret mount for the stilo and have a working prototype the new brace will have adjustments at both mounts and on the bar
PNL is offline
Old 07-08-2007
Black Devil Car
oliemery311's Avatar
Trader Rating: (0)
oliemery311 has donated! United Kingdom
Fitted mine today on a 1.4 16v, no major problems, just that you have to move the stuff from the left turret(looking from outside), and when installed the brace vibrates against the thing in the image, on the upside the vibrations do make the car sound kinda beefy under acceleration but i would suggest mounting a bit further towards the back. i used 4.5mm self tapping bolts (10mm head) a 3mm bit to start the holes off but then that snapped so i just used the 4.5mm which took much longer be careful when your near to going thru the turret that's when the bit snags and snaps. thamks for the thread ben. now its time to go test it out properly!
ID:	31376  Click image for larger version
oliemery311 is offline
Old 09-08-2007
Black Devil Car
Trader Rating: (0)
that good vibration has turned into problem vibration, the clip that holds the plug into the ecu has snapped, and now the plug comes out and the car cuts out! on an island! anyone know what to do?
Old 11-04-2008
maruno88's Avatar
Trader Rating: (0)
Hi! Houmies! I´m new here, i live in Spain and i bought a front&rear Strutbrace for my Fiat Stilo "stilin" 1.4 16v. 95hp. Good. I received the strut braces but i don´t know how to fit the bars.... the front with this tutorial... perfect except one thing.... not have sujection for below? only a 3 screw? not hit with a suspension?
But... What happened with the rear strutbrace? I don´t know how install. I need your help please because i bought the bars and i believe how install it but I am a silly. Thanks very much. I wait your help.
If you should have the amability of upload a photo... better. Thanks all.
maruno88 is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Anti roll bar or strut brace? fredjudd Cinq/Sei > Technical 31 03-10-2005 21:47
Arrrh! Strut Brace help plz.. _CinqueCento_ Cinq/Sei > Technical 8 28-01-2005 16:29
Front lower strut brace for seicento tearer Cinq/Sei > Technical 2 20-04-2004 17:01
Front strut bolt (30mm lowered pics too) Bushboy Cinq/Sei > Technical 25 17-03-2004 07:18
Strut Brace Mikey_B Cinquecento / Seicento 13 09-03-2004 20:18
