Hi new member here, I've tried to post this already but it obviously didn't work.
I recently saved a Punto gt from someone's garden. After much cleaning I got the engine started but it was idling from 1000-3000 rpm and trying to stall.
I changed the idle control valve but this made no difference.
When I changed the plugs and leads it idled from 1500-2500 rpm but it was a lot smoother and stopped miss firing.
I've searched the Internet and forums so please don't think I've jumped in with a common problem and no done no research.
Only thing I haven't check is the boost pipes, I've had a quick look but not in detail.
I also got 2 engines with the car but there different, I'm guessing the idle control is on the inlet on later models.
The car is a 96 model with 99k on the clock. Doubt it's anything to do with it but the dials don't work except the rev counter (not sure about the speedo because I haven't driven it) all fuses are fine as well.
I'll post a video if i can get over there today
Thats the only pic I have, I know it doesn't help but maybe blue ones are different [emoji23]
