hi al, my name is vince, I'm new here and am having a nightmare with a mates gt punto. it broke down around 5weeks ago and hasn't run right since. it will start up then die, it does this 3-4 times then it idles for a few seconds and dies again, if I'm quick enough I can start it then run round the front and open throttle to rev it, it will keep bogging at which point if I feather the throttle until it picks up and get it boosting it revs ok then when its warmed up it will idle but not rev... I cannot think of anything else to try. so far I have- good fuel rail pressure
all injectors spraying good
tested coolant temp sensor
tested intake air sensor
replaced idle valve
replaced maf
replaced throttle position sensor
replaced timing belt
unwrapped the entire engine loom-checked and re-wraped
changed coil pack
replaced plugs and tested-strong spark
removed turbo,intercooler and pipework(fmic) checked and refitted
can someone suggest anything iv overlooked as I'm having a hard time with it and I feel defeated! cheers
replaced idle valve
replaced maf
changed coil pack
