According to the only previous owner, the timing belt on my 27000mile Yr2000 1.2 8v has never been changed. I opened it up, and found that when the camshaft mark is aligned correctly, the crankshaft mark is a little low.
But, using a 6mm metal rod from B&Q (with a conveniently placed barcode sticker on it) in the spark holes, I visually checked the that this is actually the 1 & 4 piston's tdc positions. When I align the crank sprocket mark as per instructions, the piston has sunk maybe 1.5mm from tdc.
I've renewed the belt, pulley, and water pump. I've set the cam and crank sprockets according to their markings, so now the cam is operating one notch later than it was. Tomorrow I hope to drive the car and see how it responds.
Anyone reads this and thinks I'm making a big mistake, let me know, ta.
