Hi guys, hope you can lend a hand here.
When I turn my engine off the oil and engine warning lights come on. As soon as the engine is turned back on they go off again. This has literally just happened of its own accord in the past few days. If any other LED's (eg City, petrol warning, door open) are on, they too stay on.
Before this I had an issue where the handbrake light would stay on when the engine was turned off, however if i turned the engine on and then off again this it stayed off. This did disappear of its own accord.
It's a 52 reg MK2 Punto Active 1.2. I have had a look through the forums and not found anything that seems to relate to this, however I may just disconnect the battery for 20 or so minutes tomorrow to see if this sorts anything.
Chris
Chris
