Thread Tools
Old 1 Week Ago   #1
Map sensor question (to add to the list )
Thanks for looking at yet another one of my clutching at straws questions re punto maintenance , if I unplug the map sensor on my 1.2l petrol punto and the engine runs smooth (which it did) and then I plug it back in again and my rough idle returns does that more than likely mean that the map sensor need replacing or cleaning ? , I know it sounds obvious but could It also be hiding something else and unplugging the sensor hides the real problem ?
Neil75 is offline Reply With Quote Quote
Old 1 Week Ago   #2
Re: Map sensor question (to add to the list )
Quote Quote:
When you unplug your MAP sensor the car will run on 'default' settings.
I had a problem with my car (not a Punto..) whereby it was kangarooing, jerking and cutting out but would restart immediately.
I did the same as you did - unplugged the MAP sensor and found that the car ran 'okayish'. Changing the MAP cured the erratic running altogether.
glenn2602 is offline Reply With Quote Quote
Thread Tools
(T) Map Sensor Fault/question chrisb7777 Cinquecento / Seicento 0 17-09-2014 21:17
(T) Map sensor question Chris017 Stilo 3 09-03-2012 00:48
(T) MAF AND MAP SENSOR question Chris017 Stilo 11 01-07-2011 08:19
(T) Map sensor question jte Punto (Mk1) 2 14-10-2008 13:25
(T) New one to add to that list DrChoda Punto (Mk2/2b) 4 20-11-2003 04:47
