- Apr 28, 2017
- 61
- 18
Dear all,
I recently obtained a 2000 punto mkii with 120000km.
It runs great, gears shift fine, but I have a problem with the clutch pedal. When depressing the pedal, it does not travel smoothly in the last few cm. The problem gets worse when the car has been running for a while, to the point where something will start squeeking and the pedal will stick to the floor. The clutch itself still works fine at this point.
Any suggestions how to solve this?
My plan is to:
1. Bleed the clutch slave cylinder (not very hopeful)
2. Replace hydraulic fluid
3. Replace slave cylinder
4. Replace master cylinder
Regarding the bleeding procedure, I removed the retaining clip at the slave cylinder but unfortunately the fluid line won't budge.
Any help would be much appreciated.
My plan is to:
