luqluq
Dear guys,
I desperately need advice on my Punto Mk2.
Recently I experienced overheating on my engine. Instead of sending the head block for skimming, I replaced it with a good working Mk2b head block together with all the gasket set.
Things I thought was fine until after running approximately 30km, I noticed that some brownish oil start to build up at the radiator bottle cap. Thinking that it was due the previous engine oil entering into water system, I flushed the water and cleaned it up. But this thing keep repeating and after running for about 100km, I removed the engine oil pan plug to see if any water entering inside but it was none!
So, its the case of engine oil goes into water and not vice versa. Check through the engine cap also showed that no sign or smell of water. After running for 500km, still the same thing happened and no water in the engine oil system and engine oil keeps entering the water system.
Your experience or knowledge in this is very much appreciated.
