- Jan 20, 2013
- 6,151
- 1,228
i disconnected battery, changed pas motor, put everything back together, pas works normally but airbag light is suddenly on
how the hell did that happen
battery voltage is good, there was no tape on light, i probably touched all those wires when i uncliped old pas motor but that shouldnt make light suddenly come on as battery was still disconnected, gonna try to reset it with mes
mes didnt show anything about airbag, probably have to change airbag ecu
You have fitted a relayless motor to a relayless power steering?
Ziggy
pas motor got 2 relays, same as old one
did you use right adapters and get into the airbag ecu?
