Re: Punto 1.9 JTD 59kw refitting a new clutch
You know about using a round piece of wood that fits well in the hole on the engine side so you can get the clutch disk centred? Make the wood thicker where it goes thru the splines with some tape wrapped around it and do your best to get the disk in the middle by looking at the wood sticking out from different viewing angles before you tighten the clutch.
.... and again:shrug::
when I'll put the bell housing in front of the engine, how do I centre the splines on the input shaft with the other ones on the clutch disk? do I have to turn manually the driveshaft ?
I'm asking because today I was trying to join the two pieces but there is that long bolt on the gearbox that goes in the hole near the starter motor, that cause problems.
The bolt is long, and I have very little room between the end of the gearbox and the lower cross member :chin:.........:bang:
(as in post nr. #20 , first photo).
