Fuse f31 - is for 3 systems
- Air conditioning
- Reverse Light
- Interior Fan relay
Since its blowing the fuse soon as the ignition is been applied, its telling me there is a dead short somewhere
I'd get some more fuses, as your gonna keep blowing them
I suspect it might be the reverse switch or a short possibly in the rear light cluster (passenger iirc)
I'd disconnect the gearbox reverse switch, this will pretty much isolate MOST of the circuit, and see if the fuse blows then
I'd also check the rear light as well, ensure the correct bulbs been fitted (p21w), Single pole, and that the wiring hasn't been tampered with
This is going to take some diagnosis time, and testing
Which is either over your head = costly mechanic / auto sparky time
OR
You loose your hair and go grey early
Ziggy
