nathanshenton
Hi, i have had a few odd/scary moments today with my brakes.
I over applied them on a steep hill this morning, and they got very hot and very smelly and completely useless, was very tricky to stop in time! So i pulled over, let them cool and went on my way. All seemed fine after that. Now I'm getting a squeak from the n/s front i think and the brakes are fluctuating between being very good and very bad. I had the front up, wheels off and discs and pads are fine. Wheels spin freely and don't seem to have rubbing at all. I have now noticed hat when I'm idling stationary and fully apply my brake pedal the car idle changes and almost seems to want to stall as i lift off the pedal. The h/brake warning light has in the last 4/5 weeks popped on and off but just gently wiggling my lever solves it immediately. checked all lines for leaks - none. not lost any fluid. brake booster and master seem fine visually. I believe to check the booster you start the car with the pedal depressed? is this right? when i do, the pedal drops slightly more when i do?
Sorry for the long post, i just want to explain the symptons. Any ideas at all?
NOTE: My pedal is very very firm and has no give in it at all
